royalblues Fri, 12/21/2007 - 02:29
When you are multihomed to 2 different routers, it is not possible to have a perfect loadbalance.
If they are multihomed to single router at both ends, then either you can do a standard CEF loadbalancing or bundle the 2 links into a single logical multilink and do loadbalancing
Narayan
