Rob Huffman Fri, 12/21/2007 - 08:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ati,
Cheers to you too my friend :)
Happy Holidays!
Rob
shane.orr Mon, 01/28/2008 - 18:54
  • Silver, 250 points or more
The link above does not work for me and I can no longer find it on the UniversCD. Has the call manager compatibility matrix gone missing....
or is this another classic case of me not being able to find bread in my own pantry. I swear my wife hides it. She calls me an idiot of course.
shane.orr Mon, 01/28/2008 - 21:40
David, yeah I had stumbled across that just beofore I posted but the excel doc that I was looking for had software compatibility like TSP Version, IPCC, Emergency Responder, etc.... I will keep poking around. I have been noticing other dead links besides this one as of late so hopefully they are re-organizing.
Rob Huffman Tue, 01/29/2008 - 05:51
  • Hall of Fame,
    Founding Member
Hi Shane,
I did just visit this link and it does have the info for IPCC, CER and links for the TSP Compatibility :)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.xls
Here is the TSP link;
Supported Version Combinations for Cisco Unity, the Cisco Unity-CM TSP, and Cisco Unified Communications Manager
Versions of Cisco Unity, the Cisco Unity-CM TSP, and Cisco Unified CM are supported only in the combinations listed;
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cutspmtx.html#wp51076
Hope this helps!
Rob
shane.orr Tue, 01/29/2008 - 06:35
Excellent, the link is working for me know, thanks as always!!
Rob Huffman Tue, 01/29/2008 - 06:54
  • Hall of Fame,
    Founding Member
You are most welcome Shane :) I guess the link has some sort of "Time of Day Routing" :)
Take care,
Rob
jzmateo1977 Tue, 01/29/2008 - 12:41
May I know if you have a compatibility matrix for Cisco Unified Communication Manager 6.X to Cisco IP Contact Center (IPCC) Enterprise Edition anc Cisco CVP. I got the ccmcompmatr.xls from this forum but when I try to access the link (Consult IPCC Matrix link) I was denied, my account has no privilege to access it.
I hope you would be able to help me on this.
Cheers,
Jon
Rob Huffman Tue, 01/29/2008 - 16:50
  • Hall of Fame,
    Founding Member
jzmateo1977 Tue, 01/29/2008 - 18:36
Hi Rob,
Thank you so much for this document. This is what we need.
Jon
Rob Huffman Wed, 01/30/2008 - 05:46
  • Hall of Fame,
    Founding Member
Hi Jon,
You are most welcome my friend! This one took alot of digging to find. I don't know why it has to be so hard :)
Best of luck!
Rob
