asa 8 and asdm 6
Dec 21st, 2007
upgraded to 8 and asdm 6 had
http server 444 found that I could no longer add subnet access
http x.x.x.x mask outside without first clearing the entire config, ading http server without a port adding the access then putting the new port back on. In addition, log just show denies when attempting to access asdm from outside though I have put in http 0.0.0.0 0.0.0.0 outside just to test. Any ideas?
irisrios Fri, 12/28/2007 - 07:28
  • Silver, 250 points or more
Reconfigure the command as http server enable 444 instead of just http server 444. If this doens't work try to reset and reconfigure the device.
whanson Wed, 01/09/2008 - 16:11
It appears that with asdm 6 and asa 8 it can distinquish between asdm access and web access. I have found it works fine w/o changing the port but doesn't if the port is changed.
