can't access router through ACS
Dec 21st, 2007
Please help I configure my DS3 router with AAA and configured ACS to talk to it however I can't log into now. Tried going through the console/aux port to no avail. Need to access router without rebooting it I didn't save the config but can't reboot router at this time. Is there a work around to log into router to take AAA off?
Collin Clark Fri, 12/21/2007 - 07:10
  • Purple, 4500 points or more
Can you post what commands you put into the router? What does your failed connection log say on ACS?
damrut5763 Fri, 12/21/2007 - 07:13
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization config-commands
aaa authorization exec default group tacacs+ none
aaa authorization commands 0 default group tacacs+ none
aaa authorization commands 1 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting send stop-record authentication failure
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
and i pointed it to my ACS server to no avail. So i can get to it via the SDM however it doesn't allow me to take the command out.
Collin Clark Fri, 12/21/2007 - 07:16
Can you login with the local username/password? What do you see in the ACS failed attempts log?
