Obtain DNS automatically from ISP by Cisco router 871
Dec 21st, 2007
I would like to obtain the DNS from ISP automatically.
I have the following DHCP configuration in my router :
ip dhcp pool guest
import all
and I added the following command on my Dialer interface :
ppp ipcp dns request
but still I do not get DNS. I can connect to Internet and ping a public address but can not browse.
Any idea please?
yjdabear Fri, 12/21/2007 - 07:28
! optional
[no ip domain-lookup]
[ip domain-name company.com]
! list your ISP DNS servers below
ip name-server xx.xx.1.xx
ip name-server xx.xx.2.xx
persepolis77 Fri, 12/21/2007 - 07:38
but by your solution, if ISP change the DNS server address, I will have to change my router configuration also.
I would like to have a dynamic configuration so that the router grab DNS information from ISP automatically!!!
yjdabear Fri, 12/21/2007 - 07:43
Ah, I see what you're saying: You want to use the DHCP-assigned DNS server(s).
yjdabear Fri, 12/21/2007 - 09:06
Well, according to this blog article, DHCP-supplied DNS parameteers are used automatically (in conjunction with any static "ip name-server" definition), but do not appear in the IOS config. So you may want to enable DHCP debugging and look at how your router sees your ISP's DHCP-supplies DNS parameters, if any.
yjdabear Fri, 12/21/2007 - 15:59
If you have "dns-server xx.xx.xx.xx" under "ip dhcp pool guest", try removing it and reboot the router.
You can see if DNS parameters are offered with "debug ppp negotiation".
Dialer1/0 IPCP: O CONFREQ [ACKsent] id 3 len 16
Dialer1/0 IPCP: Address (0x03060A000022)
Dialer1/0 IPCP: PrimaryDNS (0x81060A00000A)
Dialer1/0 IPCP: I CONFACK [ACKsent] id 3 len 16
You can see the result with "show host"
#show host
Default domain is not set
Name/address lookup uses domain service
Name servers are
andrew.butterworth Wed, 01/02/2008 - 10:03
I previously hard-coded the DNS servers in the local DHCP Scope as I couldn't get this working when I first set this up on a home ADSL router. Anyway my ISP changed their DNS server IP addresses recently so I decided to try and sort it out, so here it is...
ip dhcp pool Local-DHCP-Pool
import all
domain-name somedomain.local
lease 3 0
interface Dialer1
ppp ipcp dns request accept
It was the 'ppp ipcp dns request accept' line that I needed. Anyway it works for me.
andrew.butterworth Wed, 01/02/2008 - 10:46
I just realised you have an 871 and not an ADSL router... If your WAN is using PPPoE then I think the same still applies (i.e. the Dialer Interface). If however the WAN is just a 'normal' Ethernet connection then I assume DHCP is used to lease an IP address?, unfortunately I haven't set anything like this up before.
I did find this on CCO though:
which might be helpful?
