VPN client doesn't work in XPe
Dec 21st, 2007
The VPN client installed fine but when we attempt to run the app to even try to configure it, the UI is lock down to "simple mode". We tried to switch to the "Advance Mode" but won't do it. Also, the top menu bar in "simple mode" doesn't shows all the menus options as in regular XP. Have this client software been tested in XPe? Is it even compatible? If so, what components I need to add to XPe to get it to work as in XP? BTW, I have ALL network and communications components installed. I'm able to get network connection successfully. Thanks in advance for any help you could offer!!
