Kevin Dorrell Fri, 12/21/2007 - 07:38
  • Green, 3000 points or more
Yes it is possible. But do you mean as a client (i.e. the router gets its address from DHCP) or as a server (i.e. the router hands out IP addresses.)?
If it is client, then it is simple: ip address dhcp. If it is a server, then the configuration is rather more complicated, depending on what exactly you want it to do. Here is a good document to start with:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipr_c/ipcprt1/1cfdhcp.htm
Kevin Dorrell
Luxembourg
solpandor Fri, 12/21/2007 - 07:48
yes i meant as a server. thanks forthat link Kevin
