2948 VLAN and port configuration
Dec 21st, 2007
I want to know what are the comands to setup a port on a old CATO's switch with the following information:
switchport access vlan XX
switchport mode access
no cdp enable
spanning-tree portfast
I can do that on a IOS, but I am strugling on the old system.
Jon Marshall Fri, 12/21/2007 - 08:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
switchport access vlan XX =
set vlan XX "port number"
switchport mode access =
no real equivalent really. All ports are access ports unless you set them up as trunks.
no cdp enable =
set cdp disable ( you can use this globally or on ports )
spanning-tree portfast =
set spantree portfast "port number"
Jon
diastiago Fri, 12/21/2007 - 08:36
Jon,
Thanks for the quick reply. it works fine
TD
