Can H323 be conf'd on a 2811 w/ Advanced IP Services SW?
Dec 21st, 2007
Is Advanced Enterprise required to configure a 2811 to be a H323 GW?
Overall Rating: 5 (2 ratings)
Brandon Buffin Fri, 12/21/2007 - 10:18
You can configure an h.323 gateway with Advanced IP Services. I am currently running a 2801 with Advanced IP Services an an h.323 gateway.
Hope this helps. If so, please rate the post.
Brandon
GrayH Fri, 12/21/2007 - 11:21
Thank you for your straight forward answer. May I try another? Is Advanced Enterprise required on a 2851 to configure Gatekeeper. I plan to configure one as primary and one as alternate.
Paolo Bevilacqua Fri, 12/21/2007 - 12:50
Hi, GK in current 12.4 code requires _ivs image, so your choice is restricted to either "ip voice", or "advanced enterprise K9".
