multilink frame relay
Dec 21st, 2007
What's the maximum number of T1s that can be aggregated into a multilink on a 7609?
I have a client that wants to bundle two bundles of 8T1s together. Is this possible? If yes, what is the configuration?
Overall Rating: 4 (1 ratings)
vyam Fri, 12/28/2007 - 07:02
Thanks for the help. This doesn't exactly answer the question, but it does help. I'll try it out to see if the router will take 16 T1s.
Paolo Bevilacqua Fri, 12/21/2007 - 12:43
Which exact hardware do you have? The common limit is 12 links per bundle.
