CME 4.2 call park issue
Dec 21st, 2007
When a user puts a call on park, goes to another phone, picks the park up via speaker phone, we get one way communication. The Person that is parked can hear the person, but the person who picked up the park cannot hear the person who was parked. Any ideas?
paolo bevilacqua Fri, 12/21/2007 - 11:41
  • Hall of Fame,
    Founding Member
Which exact router and IOS image are you using ?
atomike10 Fri, 12/21/2007 - 11:43
DN Configs:
ephone-dn 52
number 30700
park-slot timeout 90 limit 15
description 30700 park DN
ephone-dn 53
number 30701
description 30701 park DN
ephone-dn 54
number 30702
description 30702 park DN
ephone-dn 55
number 30703
description 30703 park DN
ephone-dn 56
number 30704
description 30704 park DN
paolo bevilacqua Fri, 12/21/2007 - 11:43
  • Hall of Fame,
    Founding Member
Hi, can you upgrade to 12.4(11)XW5 and try again ? Also need to check phone model and firmware used.
paolo bevilacqua Fri, 12/21/2007 - 12:05
  • Hall of Fame,
    Founding Member
Hi, the XW buglist is of such an impressive size (check release notes) that unless you are running latest IOS and phone FW, you cannot receive TAC assistance if needed.
As workaround, have you tried answering with the headphone button and then press speakerphone (I assume pulling handset is not an option).
atomike10 Fri, 12/21/2007 - 12:06
I have asked my customer to try with the handset, have not received a reply yet.
atomike10 Fri, 12/21/2007 - 12:03
telephony-service
load 7914 S00104000100
load 7941 SCCP41.8-2-2SR2S
load 7961 SCCP41.8-2-2SR2S
load 7936 cmterm_7936.3-3-13-0
load 7911 SCCP11.8-2-2SR2S
41's, 61's were used for the test.
paolo bevilacqua Fri, 12/21/2007 - 12:19
  • Hall of Fame,
    Founding Member
Hi, unrelated to the issue, cisco recommends S00105000200 for the 7914.
atomike10 Fri, 12/21/2007 - 12:23
Will I stay with those phone loads with the new code? I cannot find any newer FW than that.
atomike10 Thu, 12/27/2007 - 11:52
I upgraded to the 12.4(11)XW5 and this is still an issue. It works when you pick the handset up, just not with the speaker phone.
paolo bevilacqua Thu, 12/27/2007 - 11:59
  • Hall of Fame,
    Founding Member
At this point your only choice is to work with the TAC to have this worked as a bug.
Be prepared to provide abundant "proof" of the problem, persistent to insist that a new bug is filed (ie that is NOT working as designed, nor documented anywhere that speakerphone cannot be used), and patient enough waiting a fix to be made available to you. Unfortunately the full process can take months.
atomike10 Thu, 12/27/2007 - 12:00
mgischernsnw Thu, 12/27/2007 - 19:57
That is a bug in the phone firmware, see bug ID CSCsk10873. Try upgrading to 8.3.2 or a later load and you should be alright. You might find all kinds of other bugs, but this one should be fixed at least :)
paolo bevilacqua Fri, 12/28/2007 - 01:32
  • Hall of Fame,
    Founding Member
certainly is worth to give new FW a try, however from the bug description "happens randomly" it is not a 100% match for the problem exposed (cannot hear only when picking up from parked call).
mgischernsnw Fri, 12/28/2007 - 09:10
I experienced the same "feature" that the poster described, TAC pointed me to that case, and after 2 months, the problem hasn't recurred with the new firmware.
atomike10 Fri, 12/28/2007 - 09:12
Thanks for the responses, that is definately something I am going to try. So far 8.3.2 seems to be working relatively bug free for everyone?
