Upgrade PIX PDM
Answered Question
Dec 21st, 2007
what is the latest version of PIX PDM ?
and from where i can download it ?
Correct Answer by JORGE RODRIGUEZ about 9 years 4 months ago
PDM version of PIX goes by version of code and if you are still running pix code 6.x this would be the latest codes.
Version:
PIX code 6.3(5) which is latest 6.x code for pix you will need PDM version 3.0.4
You may download pdm or PIX code here
http://www.cisco.com/cgi-bin/tablebuild.pl/pix
Rgds
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Fri, 12/21/2007 - 13:02
  • Green, 3000 points or more
Version:
Rgds
Jorge
mherald Mon, 12/31/2007 - 18:03
You download the PDM files from Cisco's CCO. You have to match your PDM/ASDM to the code you are running on your firewall, just be sure to get the right one.
Even on a PIX, especially in small numbers, the newer ADSM has some pretty nifty features in them.
Mike
