VPN tunnel within same network
Dec 21st, 2007
The problem I have is I'm backing up 2 servers at distant locations and at one of the locations I have a NAS backing each server up, each server has 2 NIC's.
1 NIC is used for normal traffic, and the other is going to be used as the network to go to the backup NAS device which will be on the same network as those NIC's. Now I currently have an ASA5505 at each location running a VPN tunnel from a x.x.x.1 network to a x.x.x.2 network. No problem there. But, the application I'm using to back the servers up requires me to have the servers on the same network. So I need to be able to create a tunnel from where each server is and have that tunnel be on the same network as the NIC's and backup NAS device if that makes any since at all.
