Problem with 857
BrazzanCisco
Was wondering if anyone could help me fugure out whats wrong with our 857 router. We wanter to upgrade our network with some vpn options, and chose the 857 router (none wlan). The problem is that we dont get an IP from our ISP. When we talk to the ISP they say that they have connection with the router, but for some reason the ip they send out doesnt stick.
We have the newest ios and the right settings(we think). Logicly, the problem seems to be something with the DHCP client thingy...
When debugging, the ISP and our router is communicating, but nothing more.
How do we continue our troubleshooting? Any ideas what the problem can be? What config should I have regarding the dhcp client protocol?
2 Accepted Solutions
most likely your ISP is using bridged and not routed encapsulation. Please configure:
interface ATM0.1 point-to-point
no ip address
no ip nat outside
no ip virtual-reassembly
bridge-group 1
interface BVI1
ip address dhcp
ip nat outside
bridge irb
bridge 1 route ip
no ip nat inside source list 1 interface ATM0.1 overload
ip nat inside source list 1 interface BVI1 overload
Let us know, please rate useful posts using the scrollbox below!
PVC 8/35 is down due to OAM failure, beside it never receives anything.
Try:
int atm0.1
pvc 8/35
no oam-pvc manage
If that doesn't resolve, something is wrong with config by ISP side.
19 Replies 19
paolo bevilacqua
Please send router configuration and the technical details from ISP (eg, if PPP is used, VCI/VPI, etc)
Here are the config andsome other files that might come in handy.
no ip address
no ip nat outside
bridge-group 1
interface BVI1
ip address dhcp
ip nat outside
bridge irb
bridge 1 route ip
Thanks man! That worked just fine, beside from the automatic DNS server update... but we solved that by statictly tell the router about the dns server addresses.
The next item on the "To do List" is to arrange VPN passthrough to our win2k server. If we have any problems in that area we will surely be using this forum again!
Good to know it worked. To automatize dns, configure:
ip domain-lookup
ip dns server
and configure clients (static or dhcp), to use router's inside address as dns.
Thanks for the nice rating, good luck and happy X-mas!
The router whent down again when we changed it's location from the testenvironment to the real location.
What happens is that the BVI1 interface is always down for some reason and we dont get any response from ISP. In this post I've included config, debug etc for troubleshooting.
Please collect "show dsl interface", "show atm pvc 8/35". No need to use atachments, it's little output.
show dsl interface
ATM0
Alcatel 20190 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.3 (ADSL2) Annex A
ITU STD NUM: 0x03 0x2
Chip Vendor ID: 'STMI' 'BDCM'
Chip Vendor Specific: 0x0000 0x6207
Chip Vendor Country: 0x0F 0xB5
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x0000 0x0000
Modem Vendor Country: 0xB5 0x00
Serial Number Near: FCZ1141R4Y3
Serial Number Far:
Modem VersChip ID: C196 (0)
DFE BOM: DFE3.0 Annex A (1)
Chip ID: C196 (0)
Capacity Used: 99% 100%
Noise Margin: 7.0 dB 7.0 dB
Output Power: 18.5 dBm 10.0 dBm
Attenuation: 11.0 dB 3.0 dB
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0x47
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 65998 (0 spurious)
PHY Access Err: 0
Activations: 2
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: init_AMR-3.0.014_no_bist.bin
Operation FW: AMR-3.0.014.bin
FW Source: embedded
FW Version: 3.0.14
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): 0 11715 0 1210
Cells: 0 0 0 7
Reed-Solomon EC: 0 0 0 0
CRC Errors: 0 0 0 0
Header Errors: 0 0 0 0
Total BER: 0E-0 0E-0
Leakage Average BER: 0E-0 0E-0
Interleave Delay: 0 58 0 15
Bitswap: enabled enabled
Bitswap success: 0 0
Bitswap failure: 0 0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 8 A C C D E E E E
010: F F F F F F F F F E E D D C B A
020: 0 0 C D E E F F F F F F F F F F
030: F F F F F F F F F F F F F F F F
040: F F F F F F F F F F F F F F F F
050: F F F F F F F F F F F F F F F F
060: F F F F F F F F F F F F F F F F
070: F F F F F F F F F F F F F F F F
080: F F F F E F F F F F F F F E F F
090: F F E E E E 2 E E E E E E E E E
0A0: E E E E E E E E E E E E E E E E
0B0: E E E E E E E E E E E E E E E D
0C0: E E E E E E D D E D E E E E E D
0D0: E E E E E E E E E E D D D E D D
0E0: D E D D D D E D E E D E E D D D
0F0: D D D D D D D D D D D E D D E E
DSL: Training log buffer capability is not enabled
erik#show atm pvc 8/35
Description: N/A
ATM0.1: VCD: 1, VPI: 8, VCI: 35
UBR, PeakRate: 1210 (2854 cps)
AAL5-LLC/SNAP, etype:0x0, Flags: 0xC20, VCmode: 0x0, Encapsize: 12
OAM frequency: 10 second(s), OAM retry frequency: 1 second(s)
OAM up retry count: 3, OAM down retry count: 5
OAM END CC Activate retry count: 3, OAM END CC Deactivate retry count: 3
OAM END CC retry frequency: 30 second(s),
OAM SEGMENT CC Activate retry count: 3, OAM SEGMENT CC Deactivate retry count: 3
OAM SEGMENT CC retry frequency: 30 second(s),
OAM Loopback status: OAM Sent
OAM VC Status: Not Verified
ILMI VC status: Not Managed
VC is managed by OAM.
InARP frequency: 15 minutes(s)
InPkts: 0, OutPkts: 0, InBytes: 0, OutBytes: 0
InPRoc: 0, OutPRoc: 0, Broadcasts: 0
InFast: 0, OutFast: 0, InAS: 0, OutAS: 0
InPktDrops: 0, OutPktDrops: 0/0/0 (holdq/outputq/total)
CrcErrors: 0, SarTimeOuts: 0, OverSizedSDUs: 0, LengthViolation: 0, CPIErrors: 0
Out CLP=1 Pkts: 0
OAM cells received: 0
F5 InEndloop: 0, F5 InSegloop: 0,
F5 InEndcc: 0, F5 InSegcc: 0, F5 InAIS: 0, F5 InRDI: 0
F4 InEndloop: 0, F4 InSegloop: 0, F4 InAIS: 0, F4 InRDI: 0
OAM cells sent: 116
F5 OutEndloop: 116, F5 OutSegloop: 0,
F5 OutEndcc: 0, F5 OutSegcc: 0, F5 OutAIS: 0, F5 OutRDI: 0
F4 OutEndloop: 0, F4 OutSegloop: 0, F4 OutRDI: 0
OAM cell drops: 0
Status: DOWN, State: NOT_VERIFIED
erik#
Try:
int atm0.1
pvc 8/35
no oam-pvc manage
:) Everything works now! Thanks alot man, you've been most kind and helpfull!!
No problem, thanks for the appreciation.
Happy Holidays too!
The router is now placed at the correct location and working just fine. next week we plan to configure vpn for remote access.
Instead of making a new post, I though I might as well post it here.
We want to allow access to the local network at the company through VPN. Basicly what we want, is to be able to get access to the local network and it's domain so that a few people can use the recources at work, from a remote location.
We figure this wont be to hard to do. As long ass we get a connection to the local network, our system handles the rest.
And the question is ?
My question is:
How do we proceed to configure the router to allow remote access without using the webinterface and software.
