Rob Huffman Sat, 12/22/2007 - 07:34
Hi Karthik,
If you are asking if the same Incoming number or Pilot Point can route to multiple Attendant Consoles, yes :)
Availability: Provision for multiple operators on same loop or pilot and monitoring same line; if operator station fails or is off line, calls are distributed to all other operators with same loops
Call distribution from a single pilot number to multiple directory numbers or user-line pairs
http://www.cisco.com/en/US/products/ps7282/products_data_sheet0900aecd80185215.html
If you are asking if Multiple Attendant Consoles can share a Directory Number, no :(
The following restrictions apply to shared lines:
•Do not use shared lines for Cisco CallManager Attendant Console pilot points or hunt group members. The phone that acts as the attendant console supports shared lines.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008053226d.html#wp1100362
Hope this helps and Happy Holidays!
Rob
