Lab Setup to train for CCNA
Dec 22nd, 2007
I know this question has been asked numerous times here for the old cert, as far as training for the new certs (640-822 & 816)
For my lab so far I have managed to source the following:
1721 (running ios v12.4 entbase)
1603R (ios v12.3 IP+)
2x Catalyst 3548-XL-EN
I understand from looking at recommendations for lab kit, that I should using 2950s instead.
My questions are:
1) Do I need more then two router??
2) Are the routers up to the job or should I be looking at other routers (26xx or 36xx series switches)
3) If the routers are up to the job what interface cards should be looking to use (WIC-1T)??
Overall Rating: 4 (2 ratings)
ccbootcamp Sat, 12/22/2007 - 20:53
  • Gold, 750 points or more
Yes, i would get another router to stick in the middle and act as a frame-switch.
Yes, I would suggest looking at the 2950 instead of the 3548XL.
Yes, WIC-1Ts will work perfect for you.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
sevanjaniyan Sun, 12/23/2007 - 15:31
Thanks for the reply brad, what router would you recommend to use as a frame switch??
ccbootcamp Sun, 12/23/2007 - 17:56
one of the following:
2520 (4 serials - 2 hi speed 2 low speed, 1 ethernet, 1 isdn)
2521 (4 serials - 2 hi speed 2 low speed, 1 token ring, 1 isdn)
2522 (10 serials - 2 hi speed 8 low speed, 1 ethernet, 1 isdn)
2523 (10 serials - 2 hi speed 8 low speed, 1 token ring, 1 isdn)
pick one of the above and it will do you just fine in your lab. :)
-brad
www.ccbootcamp.com
sevanjaniyan Sun, 12/23/2007 - 21:19
today I managed to get hold of 2x WIC-1T cards & a DTC/DCE crossover cable
+ a WS-C2950G-48-EI
Looking around It'll probably be cheaper if I went for a 2520 or 2521 I'm probably only going to add one more router into mix.
I'm going to keep my eyes peeled for another 2950 in the mean time.
