my asa5520 no informaintion for console,asa5520 power-on is startup.
Dec 22nd, 2007
since do command "delete disk0:"and "copy tftp flash:xxx.bin",asa5520 restart is abnormality and console port doesnot output. please help me.
smahbub Fri, 12/28/2007 - 12:39
Complete these steps in order to use the console port to connect the modem:
If a PC is used to configure the modem, use hyper terminal with the speed set for 9600 baud.
Use this init string in order to initialize the modem:
An OK from the modem appears.
Enter this init string also in order to disable Echo and result codes:
Change the modem dip switches to 4 and 8 down and power cycle the modem.
Remove the cable from the PC and connect it to console port.
No configuration is required on the console.
Note: Use the standard Cisco Rolled Cable along with the modem adapter.
