IPS 4240 error messages
Dec 22nd, 2007
Dear ALL,
Our Cisco IPS (all 3 of them) are not getting configuration updates. When I
try to apply them, they say they are successfully applied, but no changes
are taking place on them. When I look at the log files I see the following
Jupiter2: Deploy
Starting to Deploy...
An EditConfigDelta request sent for all the changed components.
** ECD result for analysisEngine: no error.
** ECD result for eventActionRules: no error.
** ECD result for host: no error.
Sensor has accepted all/some current config.
Unable to sync with with Tomcat. MC certificate may be invalid/expired.
Detail =java.security.cert.CertificateException: Untrusted Server
Certificate Chain
I can't find anything on the Cisco about the error I have highlighted.
Please let me know if you need any further details.
attmidsteam Mon, 12/24/2007 - 12:45
Your Ciscoworks/IDS MC certificate might be expired. I would get those regenerated and try again.
