How to check when last config changed in CatOS
Dec 23rd, 2007
I would to know if there is a way to check when last config changed for CatOS devices.
And who changed that as well.
Sometime we cant get from switch logging buffer because the buffer size full where old logs will be deleted.
Here is the same info I can get from IOS device:-
Router#sh run
Building configuration...
Current configuration : 8193 bytes
! Last configuration change at 19:59:21 CST Thu Aug 24 2006 by tiger
! NVRAM config last updated at 03:37:12 CST Fri Nov 2 2007 by lion
Thanks in advance
SiraJ
royalblues Sun, 12/23/2007 - 03:47
  • Green, 3000 points or more
I dont think there is any other way other than configuring AAA to get the log of the config chnages done on the device
Narayan
