FXS BUSY TONE
Dec 23rd, 2007
In my solution I have a 2 ports FXS VIC in 1751 router connecting through WAN to a 2 Ports FXO VIC in 1751 router , The system was working fine ,till the only ONE of the FXS ports started to give us a busy tone
what could be happened to make this situation?
could be this a result for a physical damage ?
this is the configuration for both routers , is there is any thing missed ?
Router 1 ( FXS ROUTER )
voice-port 2/0
connection plar 6510
voice-port 2/1
connection plar 6511
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 801
port 2/0
dial-peer voice 2 pots
destination-pattern 802
port 2/1
dial-peer voice 100 voip
destination-pattern 6...
session target ipv4:172.16.1.1
codec g711alaw
ROUTER 2 ( FXO ROUTER )
voice-port 2/0
timing hookflash-out 500
connection plar 800
voice-port 2/1
connection plar 801
destination-pattern 6510
port 2/0
dial-peer voice 800 voip
destination-pattern 8..
session target ipv4:172.16.1.2
codec g711alaw
destination-pattern 6511
port 2/1
Overall Rating: 5 (2 ratings)
paolo bevilacqua Sun, 12/23/2007 - 06:12
  • Hall of Fame,
    Founding Member
If you reload both routers, does it helps ?
Rob Huffman Sun, 12/23/2007 - 08:03
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Paolo,
Happy Holidays my friend! 5 points to you for all the great work you have done here this year. You are truly a wonderful asset :)
Cheers!
Rob
paolo bevilacqua Sun, 12/23/2007 - 08:29
  • Hall of Fame,
    Founding Member
Hi Rob,
I cannot write too many times how the appreciation is mutual, and I'm only returning to the user community, a fraction of the many things I've learned from this forum, and from application and study.
Have you all a great Holiday Season!
ahmedsalahomar Sun, 12/23/2007 - 23:53
Thank you for your replay
Yes I reloaded the routers but it does not work
any other steps.
thotsaphon Mon, 12/24/2007 - 22:20
  • Gold, 750 points or more
Hi ahmed
Could you do "show voice call summary" and "show voice port summary"? please post the outputs here.
Thot
