ACCESS-LIST
royalblues Sun, 12/23/2007 - 11:17
  • Green, 3000 points or more
Ali,
Can you post your configuration?
Here is a sample example of how you would configure an IPv6 access-list and verify
R1
ipv6 unicast-routing
interface Serial2/0
ipv6 address 2001::1/128 eui-64
ipv6 traffic-filter test in <--- apply access-list
clock rate 64000
ipv6 route 2001::2/128 Serial2/0
ipv6 access-list test
deny icmp any any <---- define access-list
sequence 20 permit ipv6 any any
R2
IPv6 unicast-routing
interface Serial2/0
ipv6 address 2001::2/128 eui-64
ipv6 route 2001::1/128 Serial2/0
R2#ping ipv6 2001::1
Sending 5, 100-byte ICMP Echos to 2001::1, timeout is 2 seconds:
AAAAA
Success rate is 0 percent (0/5)
R2#
R1#sh ipv6 access-list
IPv6 access list test
deny icmp any any (5 matches) sequence 10 ----------> you see hits for the access-list
permit ipv6 any any sequence 20
R1#
Narayan
royalblues Sun, 12/23/2007 - 23:48
Yes
IPv6 access-list can be created and applied even when you have not enabled ipv6 routing
Narayan
royalblues Mon, 12/24/2007 - 01:25
Can you post the config...
It will be easier to find the exact reason for not having the matches :-)
Narayan
royalblues Mon, 12/24/2007 - 01:48
You actually have multicast receiver access control enabled on the interface which restricts hosts on this subnet to joining multicast groups and this may be the reason for not seeing any hits
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/ipv6_r/ipv6_06g.htm#wp2016579
I haven't worked much on this and hence not sure whether the implcit deny rule at the end of the list would block other Ipv6 traffic as well or just multicast
Normal access-list uses the ipv6 traffic-filter command as i had shown previously
Narayan
