ccm 6.0 NFR installed on vmware
Dec 23rd, 2007
can anybody help with a vmware install, i have tried installing the 6.0 nfr twice into a fresh vmware, but i get right to the end of the install then get a fatal error and the ccm install wants to dump the info to a USB key. I have tried various disk sizes and memory setup to no avail. I have tried to install ccm 5.1 in vmare on the same box with no issues, does anybody have any tips or a vmware config file for the install. This is for a lab setup and not a production site.
Overall Rating: 5 (4 ratings)
gogasca Sun, 12/23/2007 - 14:40
  • Green, 3000 points or more
have u already tried that 6.0 media in a working server.
Just to verify DVD is ok
littledavewhite Mon, 12/24/2007 - 03:12
good idea i'll try it after christmas, do you have 6.0 NFR working in Vmare, if so which version of Vmware and what are your config option ?
cheer for the suggestion
dave white
ccie #13955
egl.gazdav Wed, 09/09/2009 - 06:03
Hi can I assume that we can download an approved VMWare image of Cisco UCM V6.0 from Cisco somewhere and that this is OK to use in a test / lab enviroment ? We have CCM V4.1 and want migrate to V6.0 but would like to test/ play in a VMWAre environment first before we purchase the V6.0 hardware which I have been told is a hardended Linux appliance ? Thanks
caishan-liu Sun, 12/23/2007 - 19:32
disk size:80G
Memory:1G
CPU:Intel
This is my vmware config.
littledavewhite Mon, 12/24/2007 - 03:11
hi could you send me your vmware config file for your setup so i can copy, maybe i have not allowed enough disk space, i went for 30 Gig and 800m ram ?
gogasca Mon, 12/24/2007 - 22:17
David attach my VMware config
littledavewhite Thu, 12/27/2007 - 08:56
hi thanks for this, i will try it in are lab when i get back to work after christmas; and let you know how i get on.
pvanvuuren Thu, 03/12/2009 - 03:59
  • Bronze, 100 points or more
Hi , where can i get a copy of this CCM 6.0 nfr software ? We'd like to test CUOM in our lab, and we need a callmanager. thanks.
phung.nguyen Sat, 05/16/2009 - 12:23
Hi! Gogasca
Could you kindly send me the zip file. We'll try to install CMM 6.0 on VMware for testing.
phung.nguyen Wed, 09/09/2009 - 07:42
Hi! Gogasca
Would you kindly send me the vmware config zip file for me to test cmm 6.x in a VM environment?.
littledavewhite Sun, 01/06/2008 - 09:55
This worked fine for me, i now have a working 6.0 in my lab, thanks for all the advice.
beacomronald Sat, 12/20/2008 - 09:56
Make sure you set hard drive space to 72 Gig. I set memory to 1024 and it works like a charm for 6.0
