Ask a qos for mpls question
Dec 23rd, 2007
in mpls vpn network, traffic based on EXP, but for P-PE link, on end PE,because PHP behavior,PE doesn't have outboud label, there is no EXP,how can PE identify the traffic class!
thank you!
Jun LI
dara111983 Mon, 12/24/2007 - 08:03
How about using the Explicit Null label instead of Implicit Null ???
the PE will be able to see the EXP marked !!!
HTH.
