Dec 23rd, 2007
what are the benifits of differnt EoMPLS technologies like Port mode, Vlan mode and dot1q mode? can any one explain me which one is appropriate for what kind of scenarios?
n.milovanov Mon, 01/28/2008 - 13:41
Hi Devang,
port mode is used when you want to pass through the ATOM circuit all the traffic from one physical Ethernet port to another physical Ethernet port.
The Vlan mode is the same but just for a single vlan. In reality port mode is rarely used most of the time you will use vlan mode.
Both are providing you point to point ethernet connection.
If you want your MPLS network to behave like virtual Ethernet switch providing point-to-multipoint services you have to use VPLS.
Regarding the dot1q mode I am not sure what exactly did you mean. If you are referencing to Q in Q tunnels that is just a way to switch through your network some dot1q tags through another dot1q tag.
Hope that this helps ;)
