ASA 5510 - SSL VPN CLIENTLESS - Remote Desktop
Answered Question
Dec 23rd, 2007
Is it possible to make a remote desktop connection with a browser via clientless SSL VPN ? I know I can do it with anyconnect SSL client but can I do it without a client ?
Correct Answer by jkeddington_2 about 9 years 1 month ago
Yes it is possible, first you will need to make sure you have the RDP plugin uploaded to the ASA. When you edit you bookmarks you will see an option for RDP.
Overall Rating: 5 (1 ratings)
jiaxu2 Wed, 12/26/2007 - 00:09
i think is not ,clientless ssl vpn only support http and https and cifs.
bob.bartlett Fri, 12/28/2007 - 19:24
Yes through SSL VPN you launch a java based client that you must load on the ASA then you get RDP through the SSL browser connection.
Correct Answer
jkeddington_2 Wed, 01/02/2008 - 15:07
blackswans Thu, 01/03/2008 - 00:06
so where can I find the RDP plugin ? and where should I upload ?
thanks
