MTU issues for transit traffic and local traffic
Dec 23rd, 2007
On my MPLS netwrok that use GSR and OSR routers , MPLS mtu is set to 1550
when i ping from one OSR to other OSR packet larger than 1500 bytes are droped but ping with more than 1500 bytes for trasit traffic is OK
I mean i can ping from one OSR to destinations behind the other OSR with packet size more that 1500
Why this is happening and why this difference exists for transit traffic and local teerminated traffics ?
ashish_gupta Mon, 12/24/2007 - 13:09
Can you give the show interface of the routers coming in between?
MPLS mtu is for the mpls packets to get fragmented when it crosses more than 1550. Anything less than that will not be fragmented. Kindly note this isnt IP mtu but mpls mtu.
Aasheesh Gupta
pooria_koleyni Tue, 12/25/2007 - 22:18
If you tell me which parametres you need about interfaces in between
All traffic are tagged
Transit traffic is ook when i ping with 1500
PIng Localy terminatiing traffic (like Loopbak) wit 1500 fails
