CTL client/eToken troubles
Dec 24th, 2007
We try now to use CTL client with Aladdin eTokens PRO32k. CTL clent connects to CM (we tried on 4.2 and on 6.0), we set CM cluster to mix mode, the message with security token insert appears. After that I insert token and press "OK", but the message appears again and again. I verified if Windows services are started (Smart Card service), and they are up. I tried to install CTL client on WinXP and Win2k3, but still no changes.
I made installation of eToken drivers from alladin web site and it shows the properties of my token, but CTL client does not.
What can be the problem?
smalkeric Mon, 12/31/2007 - 13:07
It looks like the TLS library in the phone is handling the write timeouts differently and blocks the whole keepalive thread which makes the initial connection timing out.
