ME 3750 + policing
Dec 24th, 2007
We have 2 ME 3750 connected to our internet backbone. On these devices we have our customers connected which have mailservers /internet access/.. .
The goal is to limit the traffic to the amount that our customers ordered ( 1Mbit/... ) .
I can configure policing on each interface which does the trick but I'm afraid that I will loose UDP traffic which will influence the customer's application .
Are there other methods that I can use to limit the traffic ?
srr-queue bandwidth limit is not possible because you can configure it only between 10-90 % percent but our internet backbone is only 2*16 Mbit.
srr-queue shaping/sharing seems to be difficult solution .
How is this done with our providers ? Just use the policing command ?
gr
wim
you could set the port to 10 Mbps and use the limit - that gives you 1Mbps.
If you need more granularity then use srr-queue commands and shaping, as the shape will work in the rate set by the "limit" command.
you need "srr-queue bandwidth shape" to limit the traffic, 1 number per queue.
the bandwidth limit is 1/N - so "5" gives you 20% limit on that queue.
So 10 Mbps port, 10% limit is 1 Mbps, and 20% on 1 queue gives you 200 Kbps.....
1 thing to watch is worst case delay as there doesnt seem to be much you can do to limit the buffer pool size, only shift it between the 4 different queues in a set.
Stephen
