TACACS shows "Unknown NAS" from configured device
Dec 24th, 2007
I have a router that has been configured in TACACS and suddenly started to fail login attempts.
TACACS is configured to source from the Loopback Internface on the router and I can ping it from the TACACS server.
I can log in with localy configured credentials on the router and the TACACS config is intact, I also have a switch at the same site and it is authenticating to TACACS with no problems.
When looking in TACACS, I see "Unknown NAS" with the source being the Serial Interface of the router.
Anyone ever see anything like this?
Would a router reboot be in order or possible a corrupted TACACS database?
yjdabear Mon, 12/24/2007 - 09:09
  • Gold, 750 points or more
http://www.cisco.com/en/US/products/sw/secursw/ps5338/products_user_guide_chapter09186a0080204cd4.html
"Authentication fails; the error "Unknown NAS" appears in the Failed Attempts log.
Verify the following:
•AAA client is configured under the Network Configuration section.
•If you have RADIUS/TACACS source-interface command configured on the AAA client, make sure the client on ACS is configured using the IP address of the interface specified.
Alternatively, you can configure a default NAS in the NAS configuration area by leaving the hostname and IP address blank and entering only the key."
wilson_1234_2 Tue, 12/25/2007 - 05:53
I appreciate your reply, but you are just confirming what I put in my post.
All of that has been verified.
This has been working and suddenly does not.
No config has changed, reloading the router corrected the issue.
