Issues with RisPort - No Handler found for SelectCmDevice
Dec 24th, 2007
I am getting "No Handler found for SelectCmDevice" when i am trying to send the following soap message :
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/" xmlns:tns="http://schemas.cisco.com/ast/soap/" xmlns:types="http://schemas.cisco.com/ast/soap/encodedTypes" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Header><tns:AstHeader id="id1"> <SessionId xsi:type="xsd:string">1234-20060201020721</SessionId></tns:AstHeader></soap:Header> <soap:Body soap:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><tns:SelectCmDevice> <CmSelectionCriteria href="#id1"/></tns:SelectCmDevice><tns:CmSelectionCriteria id="id1" xsi:type="tns:CmSelectionCriteria"> <MaxReturnedDevices xsi:type="xsd:unsignedInt">10</MaxReturnedDevices> <Class xsi:type="tns:DeviceClass">Phone</Class> <Model xsi:type="xsd:unsignedInt">255</Model> <Status xsi:type="tns:CmDevRegStat">Any</Status> <SelectBy xsi:type="tns:CmSelectBy">Name</SelectBy> <SelectItems href="#id2"/> </tns:CmSelectionCriteria><soapenc:Array id="id2" soapenc:arrayType="tns:SelectItem[1]"> <Item href="#id3"/></soapenc:Array><tns:SelectItem id="id3" xsi:type="tns:SelectItem"> <Item xsi:type="xsd:string">SEP00054B9C1D45</Item></tns:SelectItem> </soap:Body></soap:Envelope>
I am getting response as
<SOAP-ENV:Envelope SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"><SOAP-ENV:Header/><SOAP-ENV:Body><SOAP-ENV:Fault><faultcode>SOAP-ENV:Client</faultcode><faultstring>No Handler found for SelectCmDevice</faultstring><detail><axl:Error xmlns:axl="http://www.cisco.com/AXL/1.0"><axl:code>5003</axl:code><axl:message>No Handler found for SelectCmDevice</axl:message><request>SelectItem</request></axl:Error></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
Please help me out how to get rid of this issue.
smalkeric Mon, 12/31/2007 - 13:26
  • Silver, 250 points or more
CCM returns a fault SOAP request with HTTP error, which usually would mean an internal HTTP server error. you might have used the wrong (AXL) URL instead of using the\realtimeservice URL...
kiran_grandh Thu, 01/03/2008 - 03:27
Thanks a lot for your response. Now i used \realtimeservice... URL and i am getting "no SOAPAction header" fault message. Here is my request :
POST /axl/ HTTP/1.1
Host:20.152.16.66
Authorization: Basic Y2NtYWRtaW5pc3RyYXRvcjpub3Q0dTJj
Accept: application/soap+xml, text/*
Content-type: text/xml;charset=utf-8 ;
SOAPAction: http://schemas.cisco.com/ast/soap/action/#RisPort#SelectCmDevice
Content-length:1327
<?xml version="1.0" encoding="utf-8"?>http://schemas.xmlsoap.org/soap/envelope/" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/" xmlns:tns="http://schemas.cisco.com/ast/soap/" xmlns:types="http://schemas.cisco.com/ast/soap/encodedTypes" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> 1234-20060201020721 http://schemas.xmlsoap.org/soap/encoding/"> 10 Phone 255 Any Name SEP00054E4B1D28
Please help me out to get rid of this error.
caholman Tue, 03/18/2008 - 09:14
Is there a soap or http header that requires the AXL service url?
caholman Wed, 03/19/2008 - 21:02
I see. In this case, you have to set the request-uri as the soap:address url from the Service Definitions in RisPort.wsdl, instead of /axl/, which is the Service Definition for AXLAPI.wsdl.
