Inter_cluster Trunk
Dec 24th, 2007
Hiii Experts...
If I want to creat Inter_cluster non_gatekeeper controlled between CCM 4.2 & CCM 5.0 it could be? If yes how can I assign G729 codec between them.
Ammar
gogasca Mon, 12/24/2007 - 22:13
  • Green, 3000 points or more
Yes that will work,
Configure the Device Pool for ICT to use in Region to IP Phones G.729
Example
Cluster 1 Cluster 2
IPPhoneA ICTA IPPhone B ICT B
IPPHoneA
talks G.729 with
ICTA
amarmn1975 Mon, 12/24/2007 - 22:37
Hii gogasca ,,
I can not understand you, but.
I want to connect with another city allready have cluster and we want just to configure a trunk between the two cluster I have a local device pool and I do not know about them pool how can I configure My CCM to talk with them via trun with G729.
kolkatagtc Tue, 12/25/2007 - 20:34
You have CCM in City A and CCM in City B. Now the device pool which you have in city A is A_DvP and in city B is B_DvP. When u configure the device pool then there you need to specify the Region also. For city A the region will be A_Reg and for city B region will be B_Reg. When you create the 2 regions then just select the compression of g.729 for each other.
A_Reg ---- g.729 ---- B_Reg
B_Reg ---- g.729 ---- A_Reg
Your work is completed.
amarmn1975 Tue, 12/25/2007 - 20:54
Hiii kolkatagtc ,,
You mean that then I will assign the B_DvP to the trunk.
Thanks..
