3 extensions rings simultaneously
Dec 25th, 2007
I am using ccm 4.0. I have 3 extensions in CCM (ex. 1000, 1001, 1002). What i want is when a call comes to 1000 then all the 3 extensions rings. Can anyone tell me how it can be done.
Thanks in advance.
n.shuja Wed, 12/26/2007 - 01:11
Check the option under Route Plan --> Route/Hunt.
this should work for you.
kolkatagtc Wed, 12/26/2007 - 01:19
Nope, this doesn't works. What I want is when the call comes to the first extension then the other 2 extensions automatically rings simultaneously. I am not configuring any sharing of extensions in any phones.
Thanks in Advance.
jalston45 Wed, 12/26/2007 - 11:21
Not real sure if I not understand. But if you configure a hunt group with the "broadcast" Distribution Algorithm all extensions will ring simulaneously. Else you can choose for them to ring in order, but that I do belive are your only options.
satishy_2 Wed, 12/26/2007 - 11:32
another option :
Configure a shared DN on all the three phones eg 1005
Also if make 1005 as a part of pickup group , so that multiple call can be answered on the shared DN.
And then route the incoming calls to dn 1005.
