Help me on 7600 - drop packets
Dec 26th, 2007
I have some problems on PE-7600, on the interface GigaEthernet beside WAN, i find sometimes there are the packets dropped.
PE-T#sh int GigabitEthernet 1/1
GigabitEthernet1/1 is up, line protocol is up (connected)
xxxxxxxxx
MTU 2000 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 2/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is off
Clock mode is auto
Last input 00:00:00, output 00:00:01, output hang never
Last clearing of "show interface" counters 1d19h
Input queue: 0/2000/187/187 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 8334000 bits/sec, 1424 packets/sec
5 minute output rate 4889000 bits/sec, 1262 packets/sec
L2 Switched: ucast: 25386336 pkt, 16230235462 bytes - mcast: 53655 pkt, 5510618 bytes
L3 in Switched: ucast: 88338667 pkt, 53824812271 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 8004356 pkt, 2284353565 bytes mcast: 0 pkt, 0 bytes
114102559 packets input, 70080598427 bytes, 0 no buffer
Received 53652 broadcasts (0 IP multicasts)
0 runts, 7815328 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
104702864 packets output, 58841946059 bytes, 0 underruns
PE-T#
There isn't the congestion in the network. No QoS applied. The volume traffic total on the interface is about 10Mb/1G.
Please help me how to fix it?
Danilo Dy Wed, 12/26/2007 - 01:23
Check this link and see whether it applies to your problem http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml
BTW, what is your media type?
I have a similar problem (have drops in "Input Queue" but no flushes), ICMP also drops when test ping to the other end of the cable. But my connection is MetroE and the provider thinks its a MUX problem - we are replacing the MUX this week.
Dandy
intermediasud Wed, 12/26/2007 - 01:43
Hi Dandy,
Thanks for your reply. In my network, there is only this PE-7600 that has the problem on all interface backbone beside and sometime on client beside.
Media type is RJ45 on this interface because it's module GigaEthernet. I has the same problem on module SFP24 port.
Thanks for your link but i have read it and found nothing for me.
Any your idea is welcome.
