CCDA
Dec 26th, 2007
There are prerequisites (for example valid CCNA certification or other exams as BCMSN) in order to take the CCDA certification?
Thank you.
Best regards,
Massimiliano.
Overall Rating: 4 (4 ratings)
Danilo Dy Wed, 12/26/2007 - 05:25
Yes, CCNA is required to be certified CCDA.
However, you can take CCDA exam without having CCNA certification. You will only get the CCDA certification after you complete CCNA.
Dandy
ccbootcamp Wed, 12/26/2007 - 08:25
Massimiliano,
you were given some incorrect information above. CCNA certification is NOT a pre-req to be a CCDA:
http://www.cisco.com/web/learning/le3/le2/le0/le4/learning_certification_type_home.html
CCDA Prerequisites
CCNA level knowledge and BCMSN level knowledge is needed to prepare for the CCDA certification exam.
CCNA level KNOWLEDGE is required, but not the actual cert itself.
-brad
http://www.ccbootcamp.com
(please rate the post if this helps!)
