CCNA Questions
Dec 26th, 2007
Hi I have some questions about the CCNA.
1. Can you go back or mark the question and go back to it at the end of the exam?
2. How are the questions noted, meaning do they have the same amount of points?
3. When you enter a command can you use the TAB key to finish it? Can you use the help to find available commands?
4 How many questions in percentage do you consider as configuration questions where you have to enter commands?
5. If we know that the score to pass is 849 how many false questions can you have to pass?
Thanks for your help.
Overall Rating: 5 (1 ratings)
Danilo Dy Wed, 12/26/2007 - 05:32
  • Blue, 1500 points or more
1. Answering this question will violate NDA (Non-Disclosure Agreement)
2. I see this question everytime. It doesn't matter how many points per question, just study and pass the exam. I don't see any reason why knowing the points per question will help you pass the exam.
3. See answer in Q1
4. See answer in Q1 and Q2
5. See answer in Q2.
Good luck!
Dandy
