Ccm databese export from 3.2.(3) to 4.2
Dec 26th, 2007
I have a 3.3(2) version ccm running and i need to perform a fresh 4.2 installation; may i export de data from 3.2(2) and then import it in 4.2 using BAT?
Overall Rating: 5 (1 ratings)
Chris Deren Wed, 12/26/2007 - 08:09
No, you need use BARS to restore the database, BARS can only be restored on the same version of CallManager, so here are your options:
1. Upgrade current server to 4.2 and then take BARS backup, build your new server and restore it from BARS
2. Install CM 3.3(2) on the new server and then upgrade to 4.2.
By the way why are you upgrading to 4.2? This version is EoL and I would suggest going with 6.X.
