VLAN Security on a 3560 switch
Dec 26th, 2007
I am using this switch in my lab for testing. There are no other layer 3 devices in my lab besided this switch. if I go ahead and set up my VLANs, can I still use access lists to allow or deny connectivity between different ports (devices) on different VLANs on this layer3 switch?
Device A:
Device B:
Device C:
Device D:
How do I restrict access between Device C and Device A? In other words how can I let only Device B in VLAN2 communicate with Device A in VLAN1?
I know how to write the access list but not sure about the exact command. Would it be something like:
Access-list 101 extended permit tcp
Access-list 101 extended permit ip192.168.2.10
Where do I apply the access-group command?
Or should I use a standard access-list?
And since there is an implicit deny at the end of every access-list, all other nodes on VLAN2 will be denied accessing VLAN2, correct?
Thanks for your help.
royalblues Wed, 12/26/2007 - 08:07
access-list 100 permit ip host host
access-list 100 deny ip
int vlan 2
ip access-group 100 in
The above access-list will allow device B to talk to only device A and deny all other communications because of the implicit deny at the end
