Help with EasyVPN
Dec 26th, 2007
Hi all,
I have created easy VPN with ASA5505 at BO and 3000 concentrator at HQ. Everything works great, but when the BO ASA reboots, it looses the 'Vpnclient enable' command (even after write mem) and adds the below commands:
nat (INSIDE1) 0 _vpnc_nwp_acl
aaa authentication listener http INSIDE1 port www redirect
aaa authentication listener https INSIDE1 port 1443 redirect
Unless I remove all these commands (see below) , Iam unable to enable 'vpnclient enable' command.
HOMETEST(config)# vpnclient enable
* Remove "nat (INSIDE1) 0 _vpnc_nwp_acl"
* Remove 'aaa authentication listener' configuration
The ASA5505 has a Base license.
Please advise.
Thank you
mvsheik123 Wed, 12/26/2007 - 11:18
Hi All,
I just found the reason for "aaa authentication listener' commands. This is bug in the sw. Bug ID: CSCsh75977.
Need to upgrade/dopwngrade software, then have to check on other thing {nat (INSIDE1) 0 _vpnc_nwp_acl }
Thank you
