Why BGP Connection refused by remote host in VRF?
Can't find the reason for my BGP is not establishing in the VRF setup?
Both PE and CE can ping each other within VRF and I only see the "Connection refused by remote host" from CE router and PE is just in idle mode.
Here is my PE config:
interface Serial0/0
no ip address
encapsulation frame-relay
no ip mroute-cache
no fair-queue
clock rate 2000000
frame-relay intf-type dce
interface Serial0/0.171 point-to-point
ip vrf forwarding CRG001
ip address 10.116.0.25 255.255.255.252
frame-relay interface-dlci 171
interface Serial0/0.172 point-to-point
ip vrf forwarding CRG002
ip address 10.116.40.25 255.255.255.252
frame-relay interface-dlci 172
interface Serial0/0.173 point-to-point
ip vrf forwarding CRG003
ip address 10.116.80.41 255.255.255.252
frame-relay interface-dlci 173
router bgp 65000
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf CRG003
neighbor 10.116.80.42 remote-as 65210
neighbor 10.116.80.42 activate
no auto-summary
no synchronization
network 10.10.30.0 mask 255.255.255.0
exit-address-family
address-family ipv4 vrf CRG002
neighbor 10.116.40.26 remote-as 65209
neighbor 10.116.40.26 activate
no auto-summary
no synchronization
network 10.10.20.0 mask 255.255.255.0
exit-address-family
address-family ipv4 vrf CRG001
neighbor 10.116.0.26 remote-as 65208
neighbor 10.116.0.26 activate
no auto-summary
no synchronization
network 10.10.10.0 mask 255.255.255.0
exit-address-family
Her is the CE config:
interface Serial0/0
description VzB_ckt_W0M39897
no ip address
no ip mroute-cache
ip address 10.116.0.26 255.255.255.252
ip address 10.116.40.26 255.255.255.252
ip address 10.116.80.42 255.255.255.252
router bgp 10
no synchronization
no auto-summary
neighbor 10.116.80.41 remote-as 65000
neighbor 10.116.80.41 local-as 65210
neighbor 10.116.80.41 activate
no auto-summary
no synchronization
exit-address-family
neighbor 10.116.40.25 remote-as 65000
neighbor 10.116.40.25 local-as 65209
neighbor 10.116.40.25 activate
no auto-summary
no synchronization
exit-address-family
neighbor 10.116.0.25 remote-as 65000
neighbor 10.116.0.25 local-as 65208
neighbor 10.116.0.25 activate
no auto-summary
no synchronization
exit-address-family
Found the problem...
The PE BGP was missing the router-id:
PE#sh ip bgp vpnv4 all summ
BGP router identifier 0.0.0.0, local AS number 65000
BGP table version is 1, main routing table version 1
3 network entries using 363 bytes of memory
3 path entries using 180 bytes of memory
3 BGP path attribute entries using 180 bytes of memory
3 BGP extended community entries using 72 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 795 total bytes of memory
BGP activity 3/0 prefixes, 3/0 paths, scan interval 15 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
10.116.0.26 4 65208 0 0 0 0 0 never Idle
10.116.40.26 4 65209 0 0 0 0 0 never Idle
10.116.80.42 4 65210 0 0 0 0 0 never Idle
PE#
And is working after I created a loopback and use that as the BGP router-id, tricky...
BGP router identifier 192.168.100.1, local AS number 65000
BGP table version is 7, main routing table version 7
BGP activity 9/6 prefixes, 9/6 paths, scan interval 15 secs
10.116.0.26 4 65208 10 13 4 0 0 00:00:25 0
10.116.40.26 4 65209 10 13 4 0 0 00:00:26 0
10.116.80.42 4 65210 10 13 4 0 0 00:00:30 0
PE#
royalblues Thu, 12/27/2007 - 08:27
This could have been because BGP allocates it's router-id from global address space - so you need at least one 'up/up' interface in the default routing table
If you have all the interfaces under some or the other VRF, BGP will not be able to allocate the router-id which could have been the problem in your case
Narayan
