802.11n (CISCO?) client adapter
Dec 26th, 2007
after the release of the 1250AP, I was wondering if the 802.11n compatible client adapters were planed or close to release, and if anyone had an information about that.
I was also wondering if this AP had any particular CISCO features (like there was in some previous versions) that could require such an adapter to work properly?
Overall Rating: 3.7 (4 ratings)
Scott Fella Thu, 12/27/2007 - 18:30
I'm sure Cisco is not going to come out witha 802.11n client adapter. Intel has already released some cards along with others.... draft 2.0.
chris-marshall Tue, 01/29/2008 - 06:07
Cisco's 1250 series APs have been selected as the test hardware for all 802.11n Draft 2.0 client adapters. That means that for any Draft 2.0 compliant hardware to be certified, it must inter-operate with the 1250 series AP. There are some additional features that Cisco makes availible to client adapters (CCX, for example), but any Draft 2.0 certified client adapter should work with the 1250 without any problem, regardless of CCX version support.
Below is from the Cisco Aironet 1250 Series Access Point Q&A:
Q. What is the status of the Draft 802.11n version 2.0 standard?
A. The IEEE 802.11n working group has passed letter ballot, and this is what is known as 802.11 Draft 2.0. Subsequently, the Wi-Fi Alliance commenced compatibility testing in June 2007 to ensure interoperability of products adhering to the 802.11n draft 2.0 standard. The Cisco Aironet 1250 Series Access Point was selected as the reference platform for the Wi-Fi Alliance test bed. All products receiving Wi-Fi Alliance draft 2.0 certification must be tested with the Cisco Aironet 1250 Series Access Point.
reginald-pugh Wed, 01/30/2008 - 15:56
I have used the Linksys/Cisco WPC600N PCMCIA card, with the 1250 AP.
It with the latest driver works like a charm. Supports A/B/G radios.
This is Linksys/ Cisco's other card is here WPC4400N only does B/G radios
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
