VTP Domain
Dec 26th, 2007
we have 2 switches one switch is configured as vtp domain other switch Iam suppose to configured as client, by mistake i have configured as server, since this second switch is brand new, vtp server switch has gone down.VLAN is not comming up, however config is not changed in server switch.but VLAN is not comming up, can any one help me in this
thanks
selvakumar
glen.grant Wed, 12/26/2007 - 18:37
  • Purple, 4500 points or more
Set the new switch as client and then you have to go to the server switch and recreate the vlan , sounds like you inserted a new switch with a higher vtp config revision number and you overwrote the vlan database on the original server switch . To reset the config revision number to default give the client a vtp domain name something other than what you want to use and then set it back to the correct vtp domain name this should set the client as 0 for config revision and it won't overwrite if you insert the client back on to the net.
server---trunk-----> client switch
vtp domain name xxxx for both switches
pselva2000 Wed, 12/26/2007 - 19:03
Thanks for your help you mean do I need to change the revision number
selva
pselva2000 Wed, 12/26/2007 - 19:21
Thanks problem got resolved.I have recreated all VLAN's
pselva2000 Wed, 12/26/2007 - 19:22
Thanks I have recreated VLAN's it is working now
luismarinaray Wed, 12/26/2007 - 18:39
Selvakumar,
By default, each switch is a VTP Server,
recommended practice to insert a new switch in an already configured VTP Domain, is to promote your switch as a client, and add to your domain, so your Vlan information database is not erased, after that you could promote your switch as a server. By your post probably, you have already erased your vlan information by your new switch. I think that you will need to retype this information.
pselva2000 Wed, 12/26/2007 - 19:23
Thanks mate, problem got resolved and it is working now
