802.1x on Cisco Catalyst 2960
Dec 26th, 2007
I am trying to enable 802.1x on one of
the switchports of the Cisco Catalyst
2960:
C2960#sh run | i radius
aaa authentication login test group radius local
aaa authentication dot1x default group radius
radius-server host 10.250.97.26 auth-port 1812 acct-port 1813
radius-server source-ports 1645-1646
radius-server key 123456
C2960#sh run | i dot
dot1x system-auth-control
dot1x guest-vlan supplicant
dot1x critical eapol
C2960#conf t
Enter configuration commands, one per line. End with CNTL/Z.
C2960(config)#int g0/14
C2960(config-if)#dot1x ?
% Unrecognized command
As you can see, I can not enable 802.1x
at the interface level. The code is am running is 12.2.25SEE4:
Switch Ports Model SW Version SW Image
* 1 24 WS-C2960G-24TC-L 12.2(25)SEE4 C2960-LANBASEK9-M
System image file is "flash:c2960-lanbasek9-mz.122-25.SEE4.bin"
According to Cisco, this image supports
802.1x. Why can't enable it at the
interface level?
Can someone help me out? Thanks.
cisco24x7 Wed, 12/26/2007 - 20:53
some additional info:
C2960#sh dot1x all
Sysauthcontrol Enabled
Dot1x Protocol Version 2
Critical Recovery Delay 100
Critical EAPOL Enabled
C2960#
Jon Marshall Tue, 01/01/2008 - 11:22
Before typing dot1x under interface try
C2960(config-if)# switchport mode access
C2960(config-if)# dot1x ?
Jon
MJonkers Thu, 04/24/2008 - 04:44
This works only if switchport is access port. So configure switchport mode access.
Jagdeep Gambhir Thu, 04/24/2008 - 05:17
You must input "swithport mode access" first, then you can input 802.1x cmd.
~JG
Do rate helpful posts
