L3 as L2
Dec 26th, 2007
hello
suppose:
- i'am using L3 switches (such as 3560) as an access switch. and i need to use only L2 features. so i consider it as a L2 switch.
- my management vlan is not vlan1 but vlan50 for example
- uplinks to distribution layer are configured as 802.1q trunks.
what should i do for vlan1? put it in shutdown mode and give IP to vlan 50?
is there any command to change management vlan?
Overall Rating: 3 (2 ratings)
Fraser Reid Wed, 12/26/2007 - 23:41
yes - here is an example from my Lab on a 3750
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 10.129.28.35 255.255.255.0
so I manage that over vlan 2
on an L2 switch the
interface vlan x
ip address a.b.c.d
is enough to make vlan x the management VLAN
also the command
no ip routing
will switch off its L3 capabilities so all of the processor will be doing only L2 work.
ankbhasi Thu, 12/27/2007 - 00:21
Hi Friend,
You can configure any vlan with an ip address and shut default vlan 1. For management purpose that vlan will be active and you can manage your switch with that ip address.
But all layer 2 management traffic like CDP, STP, VTP etc traffic will still flow via vlan 1 to other switches in the network and you should not be concern with the same.
make sure you disable "ip routing" in global config mode so this switch can work only as layer 2 switch and add a default gateway to this switch so this can be managed from some remote network also.
Ankur
*Pls rate all helpfull post
ohassairi Thu, 12/27/2007 - 00:51
ok i did like you said, but i'm not able to ping devices in vlan1 (connected to access sw) from distr/core sw.
in dist/core the trunk is ok:
C4507-CORE-SW01#sho int gigabitEthernet 4/2 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
in access sw trunk is also ok:
C3560-ACC-SW21#sho int gigabitEthernet 0/1 switchport
Switchport: Enabled
what could be the reason? can't even find mac address in ARP table in dist/core.
Voice VLAN: none
Protected: false
ankbhasi Thu, 12/27/2007 - 00:57
Hi Friend,
Can you please confirm when you initiate ping you are doing it from the core switch itself? or from some machine which is in vlan 1? Or from some machine which is in another vlan?
If you are initiating ping from core switch itself do you have any layer 3 interface created for vlan 1 on your core switch?
Ankur
ohassairi Thu, 12/27/2007 - 01:36
yes i'm pinging from dist/core. of course it contains an ip address in vlan 1 in the same subnet of the pingued device.
in sho ip route the route exists as connected. i'm afraid the ARP request is not going via the uplinks.
dist/core--.1q--sw1--.1q--sw2--device.
vtp is ok. :-(
Fraser Reid Fri, 12/28/2007 - 06:01
if you have SHUTDOWN VLAN 1 on the Switch you are trying to ping from then of course it will not work.......
ohassairi Fri, 12/28/2007 - 06:29
that's why my question was should i shutdown vlan1 or no>
if this is really the reason, so in my senario vlan1 can't spread in many switches?
but note i shutdown interface vlan1 (L3) and not vlan1(L2).
so i am not sure this is the reason of my problem.
any comment?
ankbhasi Fri, 12/28/2007 - 06:59
Hi Friend,
You mentioned you are not able to ping devices in vlan 1 so even if you interface vlan 1 is hut on that switch it does not make any difference.
I am sure some very basic thing is missing in your config? Just check the trunk connections again between all the switches? Also check the "sh interface vlan 1" on your dist switch and make sure it is up and up?
Also can you try pinging vlan 1 interface ip address from devices which are in vlan 1 on this switch? Can you check for any firewall installed on your devices in vlan 1?
Ankur
Fraser Reid Sat, 12/29/2007 - 14:12
To ping a Device (another switch) in VLAN 1 you need to have a L3 address assigned to it
interface vlan 1
no shut
ip address a.b.c.d
I think I am missing your point here :-/
ohassairi Sat, 12/29/2007 - 20:21
the device i want to ping is a computer in vlan 1 and not a switch.
all switches have ip address in vlan 50 (management vlan) and they have shutdon on interface vlan1.
Jon Marshall Sun, 12/30/2007 - 09:47
What is the default-gateway set to on the client computer ?. Presumably it is the vlan 1 interface on the core switch - is that correct.
Is the core switch responsible for inter-vlan routing. So can you ping the vlan 1 interface on the core switch from the vlan 50 interface (or whatever management vlan you used) on your access-layer switch ?
Jon
shrikar.dange Sun, 12/30/2007 - 23:06
A trunk port configured with IEEE 802.1Q tagging can receive both tagged and untagged traffic. By default, the switch forwards untagged traffic in the native VLAN configured for the port. The native VLAN is VLAN 1 by default.
The native VLAN can be assigned any VLAN ID.
Beginning in privileged EXEC mode, follow these steps to configure the native VLAN on an IEEE 802.1Q trunk:
Command Purpose
Step 1
configure terminal
Enter global configuration mode.
Step 2
interface interface-id
Define the interface that is configured as the IEEE 802.1Q trunk, and enter interface configuration mode.
Step 3
switchport trunk native vlan vlan-id
Configure the VLAN that is sending and receiving untagged traffic on the trunk port.
For vlan-id, the range is 1 to 4094.
Step 4
end
Return to privileged EXEC mode.
Step 5
show interfaces interface-id switchport
Verify your entries in the Trunking Native Mode VLAN field.
To return to the default native VLAN, VLAN 1, use the no switchport trunk native vlan interface configuration command.
If a packet has a VLAN ID that is the same as the outgoing port native VLAN ID, the packet is sent untagged; otherwise, the switch sends the packet with a tag.
shrikar.dange Mon, 12/31/2007 - 00:12
hi,
In my opinion as you have shut down the VLAN 1 you are not able to ping any device which is very obvious.You have to give no hsut command.
The CDP,STP,VTP uses vlan 1 to transer the info even though you have created another management VLAN.Also you can not prune VLAN 1 for the same reason.Plz do not shut the vlan 1 interface and check the ping.
Hope this helps.
shri :)
ohassairi Mon, 12/31/2007 - 23:22
i am sorry, i think the problem is in computers, because in other computers this problem does not occur.
but one thing is sure if we put shutdown or we don't put shutdown under interface vlan1 (that has no ip address) in access switch, computers in vlan1 can reach their gateway that is in core switch.
