EIGRP Wildcard command
Dec 27th, 2007
Can some explain what is the purpose of the wildcard in EIGRP.
When should it be used?
When should it no be used?
Why would we use it on a loopback interface?
Please let me know..
royalblues Thu, 12/27/2007 - 00:26
EIGRP wildcard masks are used to control the interfaces on which you want the EIGRP to operate
For eg.. say if you have 3 interfaces having the following ip address 10.10.10.1/24 10.10.20.1/24 and 10.10.30.1/24
Now if you use the follwoing network command under EIGRP
router eigrp 100
network 10.0.0.0
it will start EIGRP on all the interfaces but if you wanted to run it on only 10.10.10.1 you would use
router eigrp 100
network 10.10.10.1 0.0.0.0
The case is similar for loopbacks as we generally use /32 subnet mask for them and hence need not want to run EIGRP on the entire subnet
Narayan
Mavrick25 Thu, 12/27/2007 - 00:59
Is it safe to say that with loopback interfaces there really isn't a need to include the wildcard then.
because it is a /32?
What do you think?
It really isn't a practice that I am used to performing..
Let me know..
royalblues Thu, 12/27/2007 - 02:25
It depends
say for example you have 3 loopbacks defines
Lo1-10.10.10.1/32, LO2-10.10.10.2/32, LO3-10.10.10.3/32
Now if you configure
router eigrp 10
network 10.10.10.0 ---> this will be converted to 10.0.0.0 and EIGRP will run on all interfaces
If you wanted to trestrict on one interface
you would do
router eigrp 10
network 10.10.10.0 0.0.0.0
Again, it totally depends upon the user requirements. Generally it is a best practice to not turn on EIGRP on the interfaces that need be running them
Narayan
a.hajhamad Thu, 12/27/2007 - 04:38
Hi Narayan,
Just to correct:
you would do
router eigrp 10
I think you mean network 10.10.10.(1) "not 0" 0.0.0.0
and i think for the interface to use the subnet mask "wildcard" for the interface
For example:
interface serial 1/0/0
ip address 10.10.10.1 255.255.255.0
you have to add
router eigrp 10
network 10.10.10.1 0.0.0.255
Right?
abd Alqader
royalblues Thu, 12/27/2007 - 04:42
Yes..
thanks for correcting the typo
it should have been 10.10.10.1 0.0.0.0
Narayan
Mavrick25 Thu, 12/27/2007 - 05:30
I have another question:
It makes perfect sence for subnet addresses because the subnets are attached to the interface.
turning our attention to loopback address..
if configuring a loopback interface lets say:
loopback 0
3.3.3.3 255.255.255.255
This is a virtual address, logical not assigned to an interface.
How can you control which interface propagates the address out..
a.hajhamad Thu, 12/27/2007 - 05:39
The router will propagates this address "loopback" to its EIGRP neighbors using the interfaces used for establishing the EIGRP neighbors.
If you want to control the Propagation process, use distriubute-list command inside the EIGRP config.
Abd Alqader
