Multicust Stream
Dec 27th, 2007
Hi all,
Is there any option if my two path with same cost available to reaching sender end ,multicust will flow with only one path so that replicated packet will not come twise .
smalkeric Wed, 01/02/2008 - 13:22
There is an issue of loss of predictability of the path of multicast streams across the various equal cost links.Traffic is only load split between different sources, not different . Make sure you have a larger number of source, load-splitting is statistical based on source address: If you only have two sources.
