Hello Tech's
In CME, have following ephone-dn (8 digits).
ephone-dn 1 dual-line
number 81004460
With the command below,
dialplan-pattern 1 0353245... extension-length 8 extension-pattern 81004...
Able to see both extension (8 digits) and E.164 (10 digits) numbers as follow with
"sh dial-p vo sum", which is expected behavior.
20001 pots up up 81004460$ 0 50/0/1
20024 pots up up 0353245460$ 0 50/0/1
dialplan-pattern 1 53245... extension-length 8 extension-pattern 81004...
I only see extension (8 digits) number and no E.164 (8 digits) number as
follows:
20001 pots up up 81004460$ 0 50/0/1 which is there due to the number command under ephone-dn 1
AFAIK dialplan-pattern is used to extract and prefix the extension number from and to a longer DID number, but here the dialplan-pattern, extension-length and pattern are 8 digits, can this be done or cannot.
