multiple ip on 1 asa5520 interface
Dec 27th, 2007
Is it possible to have multiple ip on 1 interface?
We are migrating from concentrator3030 tot asa5520 and want to do it stepwise: tunnel by tunnel and at the end take over the ip from the 3030.
I tried to make a subinterface but then asa complains that the subnetmask is the same as another interface.
husycisco Thu, 12/27/2007 - 05:05
Hi Dominique
Only way is creating subinterfaces on a trunking enabled real interface which I assume you tried. ASA complains about the subnetmask issue because ASA can not have more than 1 interface in same network. You should assign different networks to each interface.
