SNMP Traps from a Switch
Hi all,
I am receiving snmp traps on my server from a switch telling me that interface FastEthernet0/1 is down.
I do not have trap notification turned on that should alert me for this type of information.
I do not care about individual interface notifications and I would like for this switch to stop sending these notifications.
How should I go about doing this?
Here is the snmp config for this particular switch:
snmp-server engineID local xxx
snmp-server community ***** RO
snmp-server community ***** RW
snmp-server location *****
snmp-server chassis-id 0x17
snmp-server host 10.120.11.10 *****
Thanks!
Overall Rating: 4 (2 ratings)
David Stanford Fri, 12/28/2007 - 07:34
  • Cisco Employee,
This would be correct if he had enabled traps, but traps were not enabled. In this case the snmp-server host command actually doesn't send anything.
He would also need snmp-server enable traps configured for it to send anything.
PAUL TRIVINO Fri, 12/28/2007 - 19:43
  • Bronze, 100 points or more
On the interface about which you wish not to have traps sent, in int config mode enter "no snmp-trap link-status" (check the syntax). We use this on non-critical ports (like user PC ports) but still send traps on interswitch/uplink ports.
Paul
