Can't Connect to VPN Client
Dec 27th, 2007
I am trying to resolve a connection issue with Cisco VPN Client Ver Below is the log file data and the messages I get when I try to connect the VPN. I added the VPN I.P. to my ZA-AV firewall trusted zone, and I have attempted the connection with and without personal firewall. I also verified the password and username.
System OS: Vista Home Premium (pre-loaded)
There were no reported issues during installation of VPN client software:
Firewall is ZoneAlarm v7.x
Log reports:
Cisco Systems VPN Client Version
Client Type(s): Windows, WinNT
Running on: 6.0.6000
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
1 18:55:47.664 12/25/07 Sev=Warning/3 IKE/0xE3000057
The received HASH payload cannot be verified
2 18:55:47.664 12/25/07 Sev=Warning/2 IKE/0xE300007E
Hash verification failed... may be configured with invalid group password.
3 18:55:47.664 12/25/07 Sev=Warning/2 IKE/0xE300009B
Failed to authenticate peer (Navigator:904)
4 18:55:47.664 12/25/07 Sev=Warning/2 IKE/0xE30000A7
Unexpected SW error occurred while processing Aggressive Mode
Overall Rating: 5 (1 ratings)
ajagadee Thu, 12/27/2007 - 08:18
Based upon the below message in the logs, the Group Name and Password is not matching.
Make sure that the Group Name and Password on both the VPN Server and Client is the same.
t.lawton Fri, 12/28/2007 - 20:22
What he is trying to say is that on the VPN termination device are you using Diffie-Hielman group 2?
rjsciscoid01 Sun, 01/06/2008 - 14:48
Arul, thank you.
Watch that caps lock. Turns out this was solution. All other userids were set under lower case. The one assigned to me was set in upper case, even though the access info I was provided indicated lower case.
