VPN IP POOLS
Dec 27th, 2007
Have an 1812 with 4 interfaces. 1-Internet, 2-VPN (attached to 1, no NAT, no split), 3-PUBLIC(NAT to 1), 4-PRIVATE (no NAT). Each with its own IP addressing and all works great with one exception. What headaches will I if I set the VPN to use same addressing as used in PUBLIC interface. VPN users just need occasional access to network equipment in 3-PUBLIC to maintain and monitor it. Nothing more.
vkapoor5 Thu, 01/03/2008 - 07:05
  • Bronze, 100 points or more
This document contains the most common solutions to IPsec VPN problems. These solutions come directly from service requests that the Cisco Technical Support have solved. Many of these solutions can be implemented prior to the in-depth troubleshooting of an IPsec VPN connection. As a result, this document is presented as a checklist of common procedures to try before you begin to troubleshoot a connection and call Cisco Technical Support.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
